Tag: high-side
![Single-Channel Smart High-Side Power Switch with Programmable Current Limit Single-Channel Smart High-Side Power Switch with Programmable Current Limit](https://www.electronics-lab.com/wp-content/uploads/2024/05/008-3-1024x740.jpg)
This is a single-channel, fully-protected, high-side power switch with programmable current-limit. Full diagnostics and high-accuracy current-sense features enable intelligent control of the load. A programmable current-limit function greatly improves the reliability of the whole...
Continue Reading![Two Channel High Side Driver with Analog Sense for Automotive Applications Two Channel High Side Driver with Analog Sense for Automotive Applications](https://www.electronics-lab.com/wp-content/uploads/2023/08/007-4-1024x739.jpg)
The project presented here is suitable for all types of resistive, inductive, and capacitive loads, and can also be used to drive LEDs. The board is built using 2 x VN5025AJ chips which are monolithic devices made using STMicroelectronics VIPower technology. It is intended for driving...
