Tag: light switch
![Analog Light Sensor + Light Sensitive Switch using OPT101 Analog Light Sensor + Light Sensitive Switch using OPT101](https://www.electronics-lab.com/wp-content/uploads/2020/11/SCH-9-1024x384.jpg)
You may have seen many light-sensitive switch circuits based on an LDR sensor. Usually, the sensitivity of the LDR based light sensor is poor. We wanted a very sensitive light switch hence we decided to make a circuit based on a light sensor rather than LDR. After a little research on...
