Voltage-Controlled Pulse Width Modulator (PWM) – PWM Signal Generator
This is an easy-to-use voltage to PWM converter. The project occupies very little space.  The circuit is built using the versatile silicon timing device LT6992-1 chip. Pulse Width Modulation (PWM) Controlled by Simple 0V to 1V Analog Input, multiturn trimmer potentiometer provided to...
