Tag: magnetic pickup
![Over Speed Sensor – Over Speed Alarm using Magnetic Pickup Sensor Over Speed Sensor – Over Speed Alarm using Magnetic Pickup Sensor](https://www.electronics-lab.com/wp-content/uploads/2022/06/001A-1-1024x649.jpg)
This is an over-speed sensor module, that provides an audible warning and signals output when the speed of a machine is above a set point. The module can be used in applications such as Engines, Machines, Sports machines, and Fitness Equipment. The speed of the machine or engine can...
Continue Reading![Under Speed Warning Alarm for Magnetic Pickup sensor – Frequency Controlled Switch Under Speed Warning Alarm for Magnetic Pickup sensor – Frequency Controlled Switch](https://www.electronics-lab.com/wp-content/uploads/2022/01/009-4-1024x653.jpg)
This is an under-speed sensor module that provides an audible warning and signals output when the speed of a machine is below the set point. The module can be used in applications such as Engines, Machines, Sports machines, Fitness Equipment, Speed of the machine or engine can be...
