Tag: MPN: 2181AL08-U
![Voltage Controlled Amplifier – VCA Voltage Controlled Amplifier – VCA](https://www.electronics-lab.com/wp-content/uploads/2024/05/004-8-1024x574.jpg)
The project presented here is a Voltage Controlled Amplifier (VCA). A VCA board helps users control the Audio Level from a remote potentiometer. It requires a single-ended audio signal in the input. Gain control voltage can be adjusted through an on-board potentiometer or use an...
