Tag: MPN: ACS37002LMABTR-050B5
![High Accuracy Current Sensor with 400Khz Bandwidth using ACS37002 High Accuracy Current Sensor with 400Khz Bandwidth using ACS37002](https://www.electronics-lab.com/wp-content/uploads/2021/01/004-1024x800.jpg)
This is a high accuracy current sensor project build using ACS37002 IC from Allegro, which is a fully integrated Hall-effect current sensor with 0.85mOhms integrated conductor. A fast overcurrent alert output, programmable gain settings and analog linear voltage outputs are key...
