Tag: MPN: AS5304A-ATSM
![Magnet Based Rotary/Linear Encoder Module with Quadrature Output Magnet Based Rotary/Linear Encoder Module with Quadrature Output](https://www.electronics-lab.com/wp-content/uploads/2023/04/002-9-1024x607.jpg)
This sensor module is a simple solution to build a magnet-based rotary encoder. The project is based on the AS5304 chip with integrated Hall elements for measuring linear or rotary motion using multi-pole magnetic strips or rings. This allows the usage of the module in applications...
