Bootloader Programmer Tool for ATMEGA328 32Pin TQFP Arduinio ISP
If you have a new ATmega328P you’ll need to burn the bootloader, to be able to upload a sketch with Arduino IDE. You can do this using this simple-to-use bootloader burning tool. The board consists of 32-pin TQPF adapter and Arduino Nano. Place the new ATMEGA328 TQFP chip into...
Fuel Gauge with OLED Display
This project enables the measurement of fuel levels in a tank using a resistive float sensor. The fuel level is measured and displayed on an OLED display. The project is compatible with Arduino and features an ATMEGA328 microcontroller. The resistive sensor, connected to a divider...
Mini Robot Controller Using Infra-Red Remote for Small and Medium Size Robot
The Robot Controller is a very compact solution for controlling small and medium size robots using an Infrared remote. The project is fully Arduino compatible and consists of an ATMEGA328 microcontroller, 2 x BD6211 motor drivers, TSOP1838 IR sensor. BD6211 H-bridge is a full bridge...
