Tag: MPN: DRV120PWR
![Solenoid, Relay, Valve Driver with Current Regulation Solenoid, Relay, Valve Driver with Current Regulation](https://www.electronics-lab.com/wp-content/uploads/2023/10/005-8-1024x1024.jpg)
The project presented here is a PWM current driver for solenoids, Relays, and valves. The board will regulate the current with a well-controlled waveform to activate and reduce power dissipation at the same time. The solenoid current is ramped up fast to ensure the opening of the...
