Tag: MPN: IFX9201SGAUMA1
![Bluetooth Robot Car Controller using ESP32 Bluetooth Robot Car Controller using ESP32](https://www.electronics-lab.com/wp-content/uploads/2024/01/001-10-1024x842.jpg)
This wireless robot car controller board is built using an ESP32 BT/Wi-Fi module, 2 x H-Bridges, 3.3V regulator. It also includes an ESP32 programming connector, power LED, screw terminal connector for the power supply, header connector for motors, and high-value capacitors on the DC...
Continue Reading![DC Motor Control Using Joystick DC Motor Control Using Joystick](https://www.electronics-lab.com/wp-content/uploads/2023/10/001-1-1024x717.jpg)
This is a compact, low-profile, and high-performance DC motor driver that provides easy control of a DC motor using a joystick. This small-size board can drive small to medium-sized brushed DC motors with up to 2.5A continuous and 6A peak currents. It is an Arduino-compatible project...
Continue Reading![6A H-Bridge with PWM-DIR input and SPI Interface 6A H-Bridge with PWM-DIR input and SPI Interface](https://www.electronics-lab.com/wp-content/uploads/2023/07/002-3-1024x670.jpg)
This 6A H-Bridge is designed for the control of DC motors or other inductive loads. The outputs can be pulse width modulated at frequencies up to 20kHz. PWM/DIR control reduces the number of PWM-capable pins needed on the microcontroller side. For load currents above the current...
