Tag: MPN: INA4180A1IPWR
![4 Channel Current Sense Amplifier – Low and High-Side Voltage Output 4 Channel Current Sense Amplifier – Low and High-Side Voltage Output](https://www.electronics-lab.com/wp-content/uploads/2023/08/003-9-1024x970.jpg)
This 4-Channel current sense amplifier is designed for cost-optimized applications. This is a current-sense amplifier (also called a current-shunt monitor) that senses the voltage drop across current-sense resistors at common-mode voltages from –0.2 V to +26 V, independent of the...
