Tag: MPN: IPW65R095C7XKSA1
![350W Power Factor Boost Converter for Inverter-Fed BLDC and PMSM Motors 350W Power Factor Boost Converter for Inverter-Fed BLDC and PMSM Motors](https://www.electronics-lab.com/wp-content/uploads/2023/08/005-4-1024x793.jpg)
This 350W power factor boost converter is designed for inverter-fed BLDC/PMSM motor appliances, A/C units, Refrigerators, and industrial power supplies. The circuit is a continuous-conduction-mode boost converter implemented using a UCC28180 PFC controller module which provides all...
Continue Reading![300W Off-line Power Factor Correction (PFC) Boost Converter 300W Off-line Power Factor Correction (PFC) Boost Converter](https://www.electronics-lab.com/wp-content/uploads/2021/07/011-4-1024x847.jpg)
The circuit presented here is a 300W off-line power factor correction (PFC) boost converter providing a nominal regulated output voltage of 375V @ 0.8A of load current. The project accommodates an input voltage range of 85V AC to 265VAC and uses average current mode control at a fixed...
