Accurate Acoustic Sensor – Sound Frequency to Voltage Converter
The project presented here is a sensitive sound sensor. The circuit converts sound frequency and outputs DC voltage.  The board consists of LM358 OPAMP and LM2907 IC. LM358 is used as a dual-stage microphone preamplifier and LM2907 acts as a frequency to voltage converter. The...
Over Speed Sensor – Over Speed Alarm using Magnetic Pickup Sensor
This is an over-speed sensor module, that provides an audible warning and signals output when the speed of a machine is above a set point. The module can be used in applications such as Engines, Machines, Sports machines, and Fitness Equipment. The speed of the machine or engine can...
Single Key Touch Sensor using LM2907
This is a single key device featuring a touch ON (Momentary) output. The project is built using the LM2907 chip. The board provides stable sensing and has a wide working power supply range 5V to 12V DC and consumes 20mA. D1 power LED, D2 function LED. Touch sensors are used in many...
Under Speed Warning Alarm for Magnetic Pickup sensor – Frequency Controlled Switch
This is an under-speed sensor module that provides an audible warning and signals output when the speed of a machine is below the set point. The module can be used in applications such as Engines, Machines, Sports machines, Fitness Equipment, Speed of the machine or engine can be...
