Tag: MPN: LM2907N-8
![Frequency To Voltage Converter (Tachometer) – Variable Reluctance Magnetic Pickup to Voltage Converter Frequency To Voltage Converter (Tachometer) – Variable Reluctance Magnetic Pickup to Voltage Converter](https://www.electronics-lab.com/wp-content/uploads/2021/12/007-5-1024x552.jpg)
The circuit shown here is a frequency-to-voltage converter that can be used in many applications. This is a signal conditioner for Variable Reluctance Magnetic Pickup Sensor used in engines or machines to detect the speed by sensing gears' teeth. The input signal level is 20mV to 28V....
