Low-Cost Boost Converter 3.3V Input – 5V Output at 250mA
This is a low-cost boost converter that converts a 3.3V input to 5V at 250mA load current. The LM2578A chip is used to build this project. The LM2578A is a switching regulator which can easily be set up for such DC-to-DC voltage conversion circuits as the buck, boost and inverting...
Step Up DC-DC Converter – 24V/10mA Output from 12V DC Input – Compatible to TO220 LDO
The project demonstrated here is a small-size solution, high-efficiency, low-cost, and low-EMI step-up DC/DC module for LDO regulator replacement. This small size module helps save on solution size and cost while also eliminating the need for a heatsink. The module takes up the same...
