Tag: MPN: LM358P
![Cooling Fan Controller Using Temperature Sensor LM35 Cooling Fan Controller Using Temperature Sensor LM35](https://www.electronics-lab.com/wp-content/uploads/2022/06/004-1024x634.jpg)
The project presented here is a low-cost solution for heat management of the heatsink and various equipment that requires automatic control of a cooling Fan. The project is built using a very cheap LM358 OPAMP. LM358 is used as a comparator, and a trimmer PR1 is provided to set the...
