Tag: MPN: LM5104MX/NOPB
![Half Bridge with Single PWM Input Half Bridge with Single PWM Input](https://www.electronics-lab.com/wp-content/uploads/2024/06/13-1-1024x588.jpg)
This is a Half-bridge module based on the LM5104 chip, which is a high-voltage gate driver. This High-Voltage Gate Driver is designed to drive both the high-side and the low-side N-channel MOSFETs in a synchronous buck configuration. The floating high-side driver can work with supply...
