Tag: MPN: LT6992-1
![Voltage-Controlled Pulse Width Modulator (PWM) – PWM Signal Generator Voltage-Controlled Pulse Width Modulator (PWM) – PWM Signal Generator](https://www.electronics-lab.com/wp-content/uploads/2021/06/001-3-1024x531.jpg)
This is an easy-to-use voltage to PWM converter. The project occupies very little space. The circuit is built using the versatile silicon timing device LT6992-1 chip. Pulse Width Modulation (PWM) Controlled by Simple 0V to 1V Analog Input, multiturn trimmer potentiometer provided to...
