Tag: MPN: LTC4071EMS8E#PBF
Simple Photovoltaic Charger – Solar Power module with Back-Up
A simple photovoltaic (PV) to Li-On battery charger project is described here. At low VCC voltage, PV current flows to both the system at VCC and the battery. When VCC reaches the programmed float voltage (4.1V with ADJ floating), the LTC4071 shunts excess current not used by the...
