Tag: MPN: LTC7000IMSE#PBF
![High Side Switch with Input Overvoltage and Overcurrent Protection High Side Switch with Input Overvoltage and Overcurrent Protection](https://www.electronics-lab.com/wp-content/uploads/2021/04/3-1024x711.jpg)
The project here is a 48V protected, high side switch designed to switch a 5A output load from input voltages from 8V to 48V. The circuit helps the user to easily ON/OFF the high current and voltage load with over-voltage lockout and over-current protection. The wide input range and...
