Tag: MPN: MAX17561AUD
![High Accuracy Adjustable Overvoltage and Overcurrent Protectors using MAX17561 High Accuracy Adjustable Overvoltage and Overcurrent Protectors using MAX17561](https://www.electronics-lab.com/wp-content/uploads/2021/03/004-1-1024x637.jpg)
If you need safe power to run your project, then this circuit is a possible solution for you. This project provides protection to your system device against over-current, over-voltage, under-voltage, thermal overload, and reverse current flow control to the system device. Basically,...
