Tag: MPN: MAX17600ASA+
![2 Channel MOSFET Module 2 Channel MOSFET Module](https://www.electronics-lab.com/wp-content/uploads/2024/05/007-1024x594.jpg)
This is a low profile and small size two-channel MOSFET board that can drive loads up to 2 x 3A. The Power Supply is 5V to 14V DC. Inputs and input Enable are TTL-level signals. The Output is by default enabled and an active high signal disables the output. Parallel Operation of Dual...
