Tag: MPN: MAX5048CAUT+T
High Current MOSFET Based Power Switch with Gate Driver
This power load switch project provides a simple and inexpensive method for power control. It is intended for driving a resistive or inductive load. A TTL logic signal from the system turns the load switch ON and OFF. The project consists of a low ohm N-Channel Power Trench MOSFET...
