Tag: MPN: MAX835EUK+T
![Under Voltage Lockout Relay – Latching Voltage Monitor Under Voltage Lockout Relay – Latching Voltage Monitor](https://www.electronics-lab.com/wp-content/uploads/2022/08/004-1-1024x649.jpg)
This project prevents/disconnects the load when an under-voltage condition occurs. The circuit latches the output when input sense voltage drops below the lockout threshold. Lockout threshold voltage can be adjusted using the onboard trimmer potentiometer PR1. Tactile switch SW1 is...
