Tag: MPN: NCV1124DR2G
![Stepper Motor Based Rotary Encoder with Clock and Up/Down Direction Signal Output Stepper Motor Based Rotary Encoder with Clock and Up/Down Direction Signal Output](https://www.electronics-lab.com/wp-content/uploads/2023/04/010-9-1024x617.jpg)
This project enables the users to use a stepper motor as a rotary encoder for position control and Up/Down direction control. A bipolar stepper motor can be used as a rotary sensor as it generates two channel strings of pulses by turning the shaft. The circuit provides Step pulse and...
Continue Reading![Dual Variable – Reluctance Sensor Interface Module – Stepper Motor Based Incremental Rotary Encoder Dual Variable – Reluctance Sensor Interface Module – Stepper Motor Based Incremental Rotary Encoder](https://www.electronics-lab.com/wp-content/uploads/2022/07/001-1-1024x717.jpg)
This project offers a dual−channel low component count interface solution for ground-referenced variable reluctance sensors. Each of the two identical channels interfaces with a variable−reluctance sensor, and continuously compares the sensor output signal to a user−programmable...
