Tag: MPN: NE555PE4
![LED Fading Effect / LED Strobe using 555 LED Fading Effect / LED Strobe using 555](https://www.electronics-lab.com/wp-content/uploads/2021/01/B-1024x737.jpg)
In general, generating an LED fade effect requires a microcontroller or another expensive circuit. We have built this low-cost LED fading board using an inexpensive 555 Timer. The 555 timer is used as an astable multivibrator, which generates low-frequency pulses, further, this pulse...
Continue Reading![60W LED Dimmer for 12V LEDs using 555 Timer 60W LED Dimmer for 12V LEDs using 555 Timer](https://www.electronics-lab.com/wp-content/uploads/2021/01/3333-1-1024x662.jpg)
The project shown here is a cheap 60W LED dimmer for 12V LEDs/12V LED strips. The circuit is based on the very popular, versatile, and low-cost 555 timer IC, NE555 IC generates a PWM signal and IRF540 MOSFET works as output driver for the LEDs. In this circuit the 555 IC used in an...
