Tag: MPN: NR110K
![5V – 4A Buck Converter using NR110E 5V – 4A Buck Converter using NR110E](https://www.electronics-lab.com/wp-content/uploads/2023/04/003-1024x634.jpg)
This powerful buck converter can efficiently produce 5 V@4A with an input voltage between 7V to 31V. The project is built using the NR110E chip from Sanken Semiconductor. The IC integrates the power MOSFET. With current mode control, ultra-low ESR capacitors, such as ceramic...
