Tag: MPN: OPA549T
![1.2V-25V/10A Adjustable Power Supply Using Power Op-Amp 1.2V-25V/10A Adjustable Power Supply Using Power Op-Amp](https://www.electronics-lab.com/wp-content/uploads/2018/01/003.jpg)
This is a small size power supply based on OPA549 power op-amp that provides output voltage 1.2V to 25V with 0 to 10A adjustable current limit. Two onboard trimmer potentiometers provided to adjust the voltage and current, LED D1 is over temperature indicator. The circuit works with...
