Tag: MPN: SC56-21SRWA
![3 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed) 3 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed)](https://www.electronics-lab.com/wp-content/uploads/2021/11/007-3-1024x638.jpg)
This is a 3 Digit 7-segment display project that contains 3 x Common Cathode displays, current limiting resistors or each LED segment, 3 x PNP Transistor on each common cathode for multiplexing etc. The project works with 5V TTL signals but can be optimized for 3.3V operations by...
Continue Reading![Arduino 4-Digit 0.5″ Common Cathode 7 Segment Display Module Arduino 4-Digit 0.5″ Common Cathode 7 Segment Display Module](https://www.electronics-lab.com/wp-content/uploads/2021/11/004-1-1024x732.jpg)
This project will help you to easily develop an Arduino compatible project that requires 4 x -7Segment 0.5" displays. The project consists of an Atmega328 microcontroller, 4 x BC847 NPN transistors to drive the common cathode displays. All displays are used in multiplexing...
Continue Reading![Arduino 3-Digit 0.5″ Common Cathode 7 Segment Display Module Arduino 3-Digit 0.5″ Common Cathode 7 Segment Display Module](https://www.electronics-lab.com/wp-content/uploads/2021/11/004-1024x735.jpg)
This project will help you to easily develop an Arduino compatible project that requires 3 x 7-Segment 0.5" displays. These are common cathode displays that use multiplexed configuration, BC847 transistor drives 3 x common cathodes, all display segments are connected to the...
Continue Reading![Arduino 2-Digit 0.5″ Common Cathode 7 Segment Display Module Arduino 2-Digit 0.5″ Common Cathode 7 Segment Display Module](https://www.electronics-lab.com/wp-content/uploads/2021/11/001-1-1024x626.jpg)
This is an Arduino compatible board for creating 2 Digit Display projects. The circuit operates with 5V DC, Connector CN1 is provided for bootloader programming and Arduino firmware upload. A new Atmega328 chip requires a bootloader and Arduino firmware programming, Connector CN1...
Continue Reading![4 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed) 4 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed)](https://www.electronics-lab.com/wp-content/uploads/2021/10/BOM-9-1024x182.jpg)
This 4 Digit 7 segment display project contains 4 x Common Cathode displays, current limiting resistors or each LED segment, 4 x PNP transistors on each common cathode for multiplexing, etc. This is a very compact project that works with 5V TTL signals but can be optimized for 3.3V...
Continue Reading![2 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed) 2 Digit Common Cathode 0.5″ – 7 Segment Display Module (Multiplexed)](https://www.electronics-lab.com/wp-content/uploads/2021/10/002-6-1024x689.jpg)
This 2 Digit 7 segment display project contains 2 x Common Cathode displays, current limiting resistors or each LED segment, 2 x PNP Transistor on each common cathode for multiplexing, etc. This is a very compact project that works with 5V TTL signals but can be optimized for 3.3V...
