Tag: Proximity Sensor
![Linear Capacitive Proximity Sensor Linear Capacitive Proximity Sensor](https://www.electronics-lab.com/wp-content/uploads/2024/02/006-1024x717.jpg)
The project presented here is an analog capacitive proximity sensor. The circuit is from Texas Instruments application note. Most conventional capacitive proximity sensors produce a "1" or "0" output, this circuit produces a DC output that is a function of the size and relative...
Continue Reading![Inductive Proximity Sensor using TCA505 Inductive Proximity Sensor using TCA505](https://www.electronics-lab.com/wp-content/uploads/2019/05/IMG_47397.jpg)
The circuit published here is an Inductive Proximity Sensor, which is used for non-contact detection of metallic objects. The circuit can be used for the detection of metal objects or as a positioning sensor. The TCA505 is used to design an inductive proximity switch that can detect a...
