Tag: step-down
![Stepdown DC-DC Converter with Current Limit Stepdown DC-DC Converter with Current Limit](https://www.electronics-lab.com/wp-content/uploads/2022/11/002-1-1024x653.jpg)
The step-down DC-DC Converter project presented here provides 3.3V @ 1A output from an input range of 8V to 36V DC. The adjustable current limit is an important feature of the project, which prevents the device from accidental output short circuits avoiding excessive load damage. The...
Continue Reading![High Current Half-Bridge with Over Current & Voltage Feedback for Step Down DC-DC Converter High Current Half-Bridge with Over Current & Voltage Feedback for Step Down DC-DC Converter](https://www.electronics-lab.com/wp-content/uploads/2022/03/001-1024x764.jpg)
This project enables the user to create a high current DC-DC converter. The project consists of a high current inductor, high current low voltage 2 x MOSFETs, half-bridge driver LT1158 chip, voltage feedback using onboard R9 and R10 resistor dividers, shunt resistor for overcurrent...
Continue Reading![60V Input – 5V @ 50mA Output High Voltage Fixed Output Regulator 60V Input – 5V @ 50mA Output High Voltage Fixed Output Regulator](https://www.electronics-lab.com/wp-content/uploads/2021/02/ab1-1024x811.jpg)
This is a high voltage regulator project that provides 5V regulated output with a load capacity of 50mA from input supply 10V to 60V. The project is based on the ZXTR1005K4 regulator which is fully integrated into a TO252 package. We have tested this project with 60V DC input, but the...
Continue Reading![42V Input – 3.3V @ 2A Output High Voltage Step Down Regulator 42V Input – 3.3V @ 2A Output High Voltage Step Down Regulator](https://www.electronics-lab.com/wp-content/uploads/2021/02/SCH-1024x371.jpg)
The project described here is a high voltage step-down regulator based on A4447 general-purpose buck converter chip from Allegro Semiconductor. The output voltage of the board is configured at 3.3V, but it is adjustable from 0.8 to 24V, based on the resistor divider R2 and R5....
Continue Reading![65V Input to 12Vdc Output – 1A synchronous buck DC/DC converter using LM5164 65V Input to 12Vdc Output – 1A synchronous buck DC/DC converter using LM5164](https://www.electronics-lab.com/wp-content/uploads/2021/01/003-2-1024x707.jpg)
This is a step-down DC-DC converter mainly designed for application such as high-cell-count battery packs, power tools, garden tools and electric scooters, drones. Some of the features of the project is precision enable, input voltage UVLO, internal soft start etc. The project...
