Tag: stepper motor
![Joystick Stepper Motor Controller Joystick Stepper Motor Controller](https://www.electronics-lab.com/wp-content/uploads/2023/10/002-1-1024x799.jpg)
This is a pulse generator for a stepper motor driver using a joystick. It is a board that contains an Arduino-compatible microcontroller and circuitry for controlling up to 2-channel (2-axis) stepper motors. The board has multiple options to develop stepper motor-related control...
Continue Reading![High Power Bipolar Stepper Motor Driver with SPI Interface High Power Bipolar Stepper Motor Driver with SPI Interface](https://www.electronics-lab.com/wp-content/uploads/2023/08/002-3-1024x835.jpg)
This is a compact high-power stepper motor driver built for bipolar stepper motors. The driver can be controlled using a serial communication interface (SPI). It combines a flexible ramp generator for automatic target positioning with the industry’s most advanced stepper motor...
Continue Reading![Programmable Step-Direction Pulse Generator for Stepper, BLDC and AC Servo Motor Drivers Programmable Step-Direction Pulse Generator for Stepper, BLDC and AC Servo Motor Drivers](https://www.electronics-lab.com/wp-content/uploads/2023/07/004-1-1024x765.jpg)
A programmable pulse generator is a very useful tool for stepper, BLDC, and AC servo drivers. Various stepper and servo drivers work with step and direction inputs. This project is the right solution to drive such drivers since it can provide a high-frequency output which is important...
Continue Reading![Stepper Motor Based Rotary Encoder with Clock and Up/Down Direction Signal Output Stepper Motor Based Rotary Encoder with Clock and Up/Down Direction Signal Output](https://www.electronics-lab.com/wp-content/uploads/2023/04/010-9-1024x617.jpg)
This project enables the users to use a stepper motor as a rotary encoder for position control and Up/Down direction control. A bipolar stepper motor can be used as a rotary sensor as it generates two channel strings of pulses by turning the shaft. The circuit provides Step pulse and...
Continue Reading![Dual Variable – Reluctance Sensor Interface Module – Stepper Motor Based Incremental Rotary Encoder Dual Variable – Reluctance Sensor Interface Module – Stepper Motor Based Incremental Rotary Encoder](https://www.electronics-lab.com/wp-content/uploads/2022/07/001-1-1024x717.jpg)
This project offers a dual−channel low component count interface solution for ground-referenced variable reluctance sensors. Each of the two identical channels interfaces with a variable−reluctance sensor, and continuously compares the sensor output signal to a user−programmable...
Continue Reading![High-performance, High-reliability Bipolar Stepper Motor Driver High-performance, High-reliability Bipolar Stepper Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2022/04/020-1024x771.jpg)
The project presented here is a bipolar stepper motor driver. It is based on BD63731EFV chip which is a low-consumption driver that is driven by a PWM signal. The power supply voltage of the project is 8 to 28V DC, and the rated output current is 3A. CLK-IN driving mode is adopted for...
Continue Reading![2.5A Bipolar Stepper Driver with Micro-Stepping, Current and Decay Control – Arduino Compatible 2.5A Bipolar Stepper Driver with Micro-Stepping, Current and Decay Control – Arduino Compatible](https://www.electronics-lab.com/wp-content/uploads/2021/11/007-4-1024x697.jpg)
This is an Arduino compatible board that contains an Atmega328 microcontroller and Bipolar Stepper Motor Driver chip STK682-010. This Hybrid IC from ON Semiconductor can deliver up to 2.5A current and it can have an input supply up to 32V DC. It has multiple micro-stepping options...
Continue Reading![Unipolar 4-Phase Stepper Motor Controller Unipolar 4-Phase Stepper Motor Controller](https://www.electronics-lab.com/wp-content/uploads/2015/07/C055_1.jpg)
This project is a 4-phase unipolar stepper motor controller. Description Unipolar 4-Phase Stepper Motor Controller Board will help you control a Stepper Motor or 4 individual Solenoids. This circuit consisting of transistors that serve as current amplifier and...
