Tag: thermoelectric cooler
![Dual 2A Power Amplifier Module for TEC Dual 2A Power Amplifier Module for TEC](https://www.electronics-lab.com/wp-content/uploads/2023/04/001-3-1024x631.jpg)
This Dual 2A Power Amplifier module is a low-cost operational amplifier designed for driving a wide variety of loads while operating on low-voltage supplies. The dual amplifier can drive high output loads with a current of up to 2A. This Dual 2A Power Amplifier has been designed as a...
Continue Reading![Thermistor Signal Amplifier for Thermoelectric Cooler using INA330 Thermistor Signal Amplifier for Thermoelectric Cooler using INA330](https://www.electronics-lab.com/wp-content/uploads/2022/12/002-1024x618.jpg)
The INA330 breakout board is a great tool for TEC plate temperature measurements. The INA330 based precision amplifier is designed for thermoelectric cooler (TEC) control in optical networking applications. It is optimized for use in 10k thermistor-based temperature controllers. The...
