![Propelling A Smarter Path to Industry 4.0 – Axiomtek’s eBOX671A Propelling A Smarter Path to Industry 4.0 – Axiomtek’s eBOX671A](https://www.electronics-lab.com/wp-content/uploads/2022/05/ebox671a-e1652346698864.jpg)
Axiomtek – a world-renowned leader relentlessly devoted to the research, development, and manufacturing of innovative and reliable industrial computer products of high efficiency – is pleased to announce the eBOX671A, its new fanless embedded system powered by the high-performance Intel® Xeon®, 10th generation Intel® Core™ i9/i7/i5/i3 or Celeron® processor (code name: Comet Lake-S) with the Intel® W480E chipset. With its IP40-rated heavy-duty aluminum extrusion and steel case, the durable eBOX671A can run in harsh environments with a wide operating temperature range of -40°C to +70°C and vibration endurance for up to 3G. The 9 to 48 VDC power input allows it can be used for factory automation. To enhance AI inference capabilities, the eBOX671A presents high performance for a wide range of applications in the AIoT fields such as edge computing, machine vision, deep learning, and robotic control.
“The versatile eBOX671A is designed with high computing power, easy integration, reliable operation, and rich I/O connectivity to meet the requirements of various applications at the edge. Four GbE LAN ports with optional PoE support allow this advanced embedded computer to connect IP cameras or any PoE powered device. It also has sufficient USB interfaces which are available for industrial cameras. To capture the 5G-IoT business potential, the outstanding eBOX671A is equipped with one M.2 Key B 3050 slot for 5G module,” said Janney Lee, product manager of the Product PM Division at Axiomtek. “On the front, the easy-customized eBOX671A has one easy-to-access SIM slot and one flexible I/O window which support diverse I/O choices thru Axiomtek’s PCI Express Mini modules.”
The reliable eBOX671A comes with dual 260-pin DDR4 ECC/non-ECC SO-DIMM slots for up to 64GB of system memory. The ECC memory option is available with the Intel® Xeon® processor protecting the system from a potential crash by correcting any errors in the data. Two 2.5” SATA HDD drive bays with Intel® RAID 0&1 are for extensive storage needs. It also has two full-size PCI Express Mini Card slots and two SIM slots for wireless communication. To put an emphasis on the foundation for a hardware root of trust, the eBOX671A has TPM 2.0 onboard.
Advanced Features of eBOX671A:
- LGA1200 10th gen Intel® Xeon®/Core™ i9/i7/i5/i3 or Celeron® with Intel® W480E chipset (Comet Lake-S)
- Dual 2.5″ SATA HDD drive bays with RAID 0 & 1
- 2 HDMI and 1 DisplayPort for triple view
- TPM 2.0 onboard
- -40°C to +70°C wide range operation temperature
- Wide range power input from 9 to 48 VDC
- 4 GbE LAN with optional PoE supported
- Two 10GbE LAN (X550-T2) by request
Featuring rich I/O ports for a full range of peripheral connectivity, the system comes with two lockable HDMI 1.4b, one DisplayPort 1.2++, five USB 3.2 Gen2 ports, one USB 3.2 Gen1 port, four GbE LAN ports (with optional PoE supported), two RS-232/422/485, two RS-323, one flexible I/O window, and two 10GbE LAN (optional). Other interfaces include one power button, one remote switch, one reset button, one AT/ATX quick switch, and five antenna openings. Besides, this powerful computing embedded system supports Windows 10 IoT and Linux operating system.
The eBOX671A will be available in June. For more product information or customization services, please visit our global website at www.axiomtek.com or contact one of our sales representatives at info@axiomtek.com.tw.
