![PSU Burner – a power supply tester PSU Burner – a power supply tester](https://www.electronics-lab.com/wp-content/uploads/2017/01/DSC_8259-600x399.jpg)
Bob @ electrobob.com tipped us with his latest project. It’s about a power supply tester.
What does one do when designing a power supply? Well, build a power supply tester, of course. One of the simplest things to build is a constant current load. This will allow for testing of the endurance of the power supply, as most of the designs out there are using slow components.
However, I wanted to make a better one: one that I could hook up to my Analog Discovery and generate a test waveform to be able to connect and disconnect the load fast. This is a weekend project, so all parts are not the best for the purpose, just what I had around.
PSU Burner – a power supply tester – [Link]
Login
