![PWM dimmer for RGB LED PWM dimmer for RGB LED](https://www.electronics-lab.com/wp-content/uploads/2016/03/20160128_Projekte_061-600x399.jpg)
Lukas Fassler has designed and built a PWM dimmer for RGB LED:
In my last post I’ve described the design and construction of my LED dimmer project. This project here is similar but a bit more involved. It controls RGB LEDs so it can not only change the brightness but also the color of the light. Instead of a simple pot it used a pair of rotary encoders with push buttons. One controls the brightness, pushing its button turns the light on or off. The other changes the color, pushing its button toggles between color and white.
PWM dimmer for RGB LED – [Link]
Login
