![Pyboard D Series MicroPython Board Features STM32F7 MCU, WiFi and Bluetooth Pyboard D Series MicroPython Board Features STM32F7 MCU, WiFi and Bluetooth](https://www.electronics-lab.com/wp-content/uploads/2019/02/Pyboard-D-Series.png)
Pyboard D-series (aka Pyboard D, or just PyBD) board was introduced during the Micropython presentation at FOSDEM 2019 and it’s build around a faster STM32F7 Cortex-M7 MCU, with 512Kb of RAM, and 2Mb of Flash, as well as built-in WiFi and Bluetooth connectivity. It also features a pair of external Flash chips and a micro SD card slot for additional expansion options.
The board can be programmed with MicroPython either from the command line, copying the Python file to the board (seen as a USB flash drive from your computer), or via WiFi using WebREPL terminal client.
If you are not sure, what MicroPython is, continue reading. MicroPython is a lightweight version of Python 3 optimized to run on microcontrollers, which is described as a ByteCode + virtual machine + file system compiler for the BareMetal OS implemented on the microcontroller.
![](https://www.electronics-lab.com/wp-content/uploads/2019/02/Pyboard-D-Series.jpg)
Pyboard D preliminary specifications:
- MCU – STMicro STM32F7xx Arm Cortex M7 microcontroller at 216 MHz with 512KB RAM, 2MB flash
- Storage – micro SD card slot, and 2x external flash chips
- Connectivity – WiFi & Bluetooth with on-board antenna and u.FL antenna connector
- USB – 1x micro USB port for power, flash disk access, and USB to serial debugging/programming
- Expansion
- 2.54mm pitch through holes for 16x GPIOs
- 1.27mm pitch castellated and through holes for 32x GPIOs
- 2x 40-pin WBUS connectors for a total of 59 GPIOs
- Misc – User and reset buttons, RGB LED, clock
- Dimensions – TBD
![](https://www.electronics-lab.com/wp-content/uploads/2019/02/MicroPython-STM32F7-board.jpg)
The WBUS connectors are also a new feature and will allow you to stack add-ons boards. For example the WBUS DIP28 or DIP68 boards are exposing respectively 28 and 68 I/O pins, and they can take one or more sensor board(s) via other smaller 2x 10-pin sensor board connectors.
![](https://www.electronics-lab.com/wp-content/uploads/2019/02/Pyboard-D-WBUS-DIP68-Sensor-Board.jpg)
There’s no details yet on pricing, or when the board will be released, however some on the MicroPython forum say that it could hit the market in a few days or weeks.
The pictures showed on this article have been produced by mchobby and the reference shop.mchobby.be have been removed from the original picture. I do know it because I did draw them ( https://arduino103.blogspot.com/2019/02/pyboard-d-un-nouvelle-carte-micropython.html )!
Please fix this by placing a link to the source http://shop.mchobby.be
Regards,
Dominique
Thanks for pointing me to this. We added a link to the source.
Thank for your prompt reply.
Cheers,
Dominique
