The ASUS Q670EI-IM-A is an industrial Mini-ITX motherboard that packs rich I/O capabilities, expanded connectivity and flexible customization options into a smaller and thinner board that reduces case size for space-constrained installations. With multiple display outputs, legacy options for industrial applications, GPIO ports, dual Intel LAN, as well as extensive expandability with a Mini PCIe slot, M.2 M-Key, the ASUS Q670EI-IM-A is the ideal choice for a wide range of embedded applications.
ASUS Industrial Motherboard
- DDR5 4800MHz, 2 x SO-DIMM, each 32 GB
- Supports 4 displays configuration by multiple interface: 3* DP 1.4, up to 4K resolution, 1 HDMI
- 7-year longevity supply
- 1 x PCIe 5.0 x16
- 3 x USB 3.2 Gen2 (2 x Type A, 1 x Type C), 1 x USB 3.2 Gen1 (Typ A), 4 x USB 2.0 (Typ A)
- 1 x M.2 socket with M key, type 2242/2260/2280 (PCIe x4 and SATA mode)
- 1 x M.2 socket 1 with E key, type 2230 for WIFI/BT device (PCIe and CNVi)
- 4x COM
- Power: ATX or 12V DC in (supported by our additional cable MBZ-1021)
more information: https://www.bicker.de/en/q670ei-im-a_mini-itx_asus_industrial_series_intel-q670e_alder_lake_lga1700_socket_12_gen_max_65w_tdp_motherboard
Login
