QBiP-N97A (MADN9AS): 3.5” SBC for IoT devices with Intel N97 processor, supports TPM 2.0 and dual LAN ports
1.089
The ICP Industrial Computers has recently launched the QBiP-N97A (MADN9AS) from GIGAIPC, a 3.5” SubCompact Embedded Motherboard featuring an Intel® Processor N97 with 4 cores, a maximum speed of 3.60 GHz, and a thermal design power (TDP) of 12W. Designed for industrial and embedded applications, this board supports single-channel DDR5 memory up to 16 GB, includes 2 x 2.5GbE LAN ports, and provides versatile connectivity with 4 COM ports, 1 SATA 6Gb/s port, and both HDMI and LVDS video outputs supporting multiple independent displays. Additional features include onboard TPM 2.0 for enhanced security, audio support via Realtek® ALC897, and expansion options through M.2 slots and mini PCIe. It is compatible with Windows® 10/11 (x64) operating systems and designed to operate in a wide range of temperatures (0°C to 60°C).
In small-sized places, this motherboard mainly provides solid performance. This  Motherboard is perfect for things like digital signs, factory automation, and IoT edge devices. Optional accessories, like fanless heatsinks and fansinks, are available to optimize cooling solutions.
Previously, we have written about some more interesting SBCs like the IBASE IB961 3.5″ SBC, the Radexa’s Rock 2A SBC the Banana Pi BPI-F3 SBC, and much more, feel free to check those out if you are interested in the topic.
The QBiP-N97A Specifications:
  • Processor: Intel® Processor N97 (4 cores, up to 3.60 GHz, 12W TDP, Intel 7)
    • Socket: FCBGA1264
  • Memory:
    • 1x DDR5 SO-DIMM socket, up to 16 GB
    • Single-channel DDR5 4800 MHz
  • Storage:
    • 1x SATA 6Gb/s port
  • Networking:
    • 2x 2.5GbE LAN ports (Intel® I225V)
  • Graphics:
    • Integrated Intel® UHD Graphics
    • 2x HDMI 2.0 (4096×2160 @60Hz)
    • 1x LVDS (1920×1200 @60Hz)
    • Support for 3 independent displays
  • Audio: Realtek® ALC897 codec
  • Expansion Slots:
    • 1x M.2 M-Key (2280, PCIe x2)
    • 1x M.2 E-Key (2230)
    • 1x Full-size mini PCIe with SIM slot
  • Internal I/O:
    • 1x 4-pin power connector (DC in +12V~36V)
    • 1x SATA power header
    • 1x CPU fan header
    • 1x Front panel header
    • 1x Front panel audio header
    • 1x 2W Speaker out header
    • 2x USB 2.0 headers
    • 4x COM headers (RS-232/422/485)
    • 1x Backlight Control header
    • 1x AT/ATX mode select jumper
    • 1x GPIO (8-bits) & SMBus header
    • 1x Buzzer header
  • Rear I/O:
    • 1x Headphone jack
    • 2x HDMI 2.0
    • 2x RJ45 LAN ports
    • 2x USB 3.2 Gen 2×1
    • 2x USB 2.0
  • TPM: Onboard TPM 2.0 (Infineon SLB9670VQ2.0)
  • OS Compatibility: Windows® 10/11 (x64)
  • Operating Temperature: 0°C to 60°C
  • Operating Humidity: 0-90% (non-condensing)
  • Non-Operating Temperature: -40°C to 85°C
  • Non-Operating Humidity: 0%-95% (non-condensing)
  • Form Factor: 3.5” SBC (SubCompact Board)
    • Dimensions: 146 x 101.7 mm
  • Optional Accessories:
    • Fanless Heatsink
    • Heat Spreader
    • Fansink
As far as I understand, the QBiP-N97A (MADN9AS) is a compact and versatile motherboard designed for industrial and embedded applications. It can handle up to three displays at the same time. This SBC can connect to a lot of different things. You can add extra parts to it because it has several slots, and it supports the Intel® N-series processor, so it’s perfect for digital signs or factory machines. It works with Windows 10 and 11, and it can handle really hot or really cold temperatures. Therefore, it’s a good choice for a bunch of different setups. Additionally, the cooling options help this SBC keep it running smoothly in any situation. If you need a small but powerful computer, this one’s a good choice.
This SBC is available on the ICP Industrial Computers official product page. However, you have to log into the portal to see the price, or you can get a quotation if it is not available for order.
About Debashis Das
view all posts by das
