QNAP Thunderbolt-4 All-Flash NASbook is Designed for Video Production with Hot-Swappable M.2 SSDs
1.175
QNAP TBS-h574TX Compact NASbook with 13th Gen Intel Core, High-Speed I/Os, and Storage Interface are built for video production post-production and small studios.
The device has two versions: an i5-1340PE CPU featuring 12 cores and 16 threads, a clock range of 1.80 GHz to 4.50 GHz, and Iris Xe Graphics with 80 execution units. The other variant has an i3-1320PE CPU with 8 cores and 12 threads, a similar clock range, and Iris Xe Graphics with 48 execution units. Both models have a 12MB Intel Smart Cache and efficient power consumption.
The NASbook features drive bays with an E1.S to M.2 2280 NVMe SSD adapter, allowing users to easily install either M.2 or E1.S SSDs, which is especially beneficial for RAW file editing. It also supports hot-swapping of M.2 SSDs and has an automatic RAID disk replacement function. This enables users to seamlessly exchange SSDs without disrupting the system’s operation.
This NASbook comes with dual Thunderbolt 4, 2.5GbE, and 10GbE ports, along with USB 3.2 Gen 2 ports for fast data transfer and collaborative work. It also features a 4K HDMI output and myQNAPcloud Storage for displaying raw footage and sharing files with a team.
QNAP TBS-H574TX Thunderbolt-4 All-Flash NASbook Specifications:
  • CPU: Intel Core i3-1320PE (13th Gen), 8-Core up to 4.5 GHz Performance, 3.3 GHz Efficiency
  • GPU: Intel UHD Graphics
  • Memory: 12 GB DDR4, 5 GB Flash
  • RAID Support: RAID 0/1/5/6/JBOD, Hot-Swap Support
  • Networking: Supports AFP, CIFS/SMB, FTP, HTTP, HTTPS, iSCSI, SNMP, SSH, SSL, TFTP, Telnet, WebDAV
  • Bays: 5 x E1.S
  • I/O Ports:
    • 2 x USB-C Thunderbolt 4
    • 2 x USB-A 3.1/3.2 Gen 2
    • 1 x USB-A 2.0
    • 1 x HDMI 1.4b Output
    • 1 x RJ45 10GbE
    • 1 x RJ45 2.5GbE
  • Drive Interface: NVMe
  • OS Compatibility: macOS, Ubuntu, CentOS, Linux, UNIX, Windows (7 and up), Windows Server (2008 R2 and up)
  • Security: 256-Bit AES, AES-NI (Hardware-Based), VPN Client Support
  • Physical:
    • Dimensions: 8.5 x 7.8 x 2.4 inches (215 x 199 x 60 mm)
    • Weight: 4.9 lbs (2.2 kg)
    • Cooling: 2 x 40 mm Fans, 1 x 75 mm Fan
    • Status Monitoring: LED Indicator, Audible Alarm
  • Electrical:
    • AC Input: 100 to 240 VAC, 50 / 60 Hz
    • Power Consumption: 46 W (Typical)
    • PSU Wattage: 120 W
  • Environmental:
    • Operating Temperature: 32 to 104°F (0 to 40°C)
    • Operating Humidity: 5 to 95%
    • Storage Temperature: -4 to 158°F (-20 to 70°C)
More details about the QNAP Thunderbolt-4 All-Flash NASbook can be found on its product page or in the press release. Priced at $1,199 at B&H, this model with an i3-1320PE processor comes with a 3-year warranty, extendable to 5 years.
About Debashis Das
view all posts by das
