The QuartzPro64 is a developer board powered by the Rockchip RK3588 SoC, offering high-performance computing, extensive connectivity, and flexible expansion options. It features an octa-core CPU with four ARM Cortex-A76 cores running at 2.4 GHz and four ARM Cortex-A55 cores at 1.8 GHz, along with a Mali G610MC4 GPU with four Valhalla cores. The board also includes a neural network acceleration engine capable of 6 TOPS, making it suitable for AI-driven applications.
For memory, the QuartzPro64 comes with 16 GB of LPDDR4 system memory and 64 GB of eMMC storage, as well as a microSD slot for further expansion. It supports a variety of display and camera interfaces, including two digital video output ports, two MIPI-DSI 4-lane connections, and MIPI-CSI/DSI for camera input. Audio is provided through a 3.5mm stereo jack with a mic input and an onboard microphone.
The board ensures strong communication capabilities with two Gigabit Ethernet ports and a Wi-Fi/Bluetooth module. These features make the QuartzPro64 ideal for applications requiring high processing power, fast connectivity, and AI acceleration.
QuartzPro64 Specifications:
- Processor: Rockchip RK3588 octa-core SoC
- 4x Cortex-A76 cores @ 2.4 GHz
- 4x Cortex-A55 cores @ 1.8 GHz
- Arm Mali-G610 MP4 GPU
- 6 TOPS NPU for AI acceleration
- 8K 10-bit video decoder, 8K video encoder
- Memory:
- 16GB LPDDR4x system memory
- Storage:
- 64GB soldered eMMC flash (Foresee)
- MicroSD card slot
- 2x SATA ports
- Networking:
- 2x Gigabit Ethernet ports (one from SoC, one via PCIe)
- Wi-Fi 5 and Bluetooth 5.0 (AMPAK Tech AP6275PR3 chipset)
- USB Ports:
- 1x USB 3.0 port
- 2x USB 2.0 ports
- 1x USB Type-C with DisplayPort alt mode
- 1x USB Type-C for debug UART
- Display Interfaces:
- 2x HDMI 2.1 outputs (up to 8Kp60)
- 2x MIPI DSI interfaces (DPHY)
- 1x HDMI input (up to 4Kp60)
- Camera Interfaces: 2x MIPI CSI interfaces (DCPHY)
- Expansion:
- 1x PCIe 3.0 slot
- GPIO buses with I²C, SPI, UART support
- Audio:
- Onboard microphone
- 3.5 mm audio jack with microphone input
- Miscellaneous:
- RTC with battery holder
- Fan header (PWM support)
- Buttons for power, maskrom, and system reset
- Power Supply: +12V DC input via barrel jack
- Dimensions: 180 x 180 mm
The QuartzPro64 offers upstream kernel support for key features such as audio, CRU, MMC, GPIO, and SATA. However, additional porting is required to enable video input/output and certain other peripherals. For detailed information, refer to the documentation page.
The QuartzPro64 Developer Board is available for purchase on the official website for $199.99. It comes with a 30-day warranty.
