Thyristor Circuit
255 viewsarduino Componenets electronics
Hello,
I’m making a circuit design to measure room or body temperature, I used Arduino Uno to receive the voltage change from the Thyristor when temp changes.
Now, I can easily convert output Thyristor voltage to temp using Steinhart–Hart equation via C++ by Arduino (1/T=A+B ln R+C(Ln R)^3).
My question is: in case I need to use electronics components without using Arduino, what of component design can make the Steinhart–Hart equation including Ln ?
Thank you
mixos Changed status to publish 27 September, 2024
Add a Comment
Write your answer.
TOP PCB Companies
