![Radino WiFi: Arduino With ESP8266EX Radino WiFi: Arduino With ESP8266EX](https://www.electronics-lab.com/wp-content/uploads/2017/01/radino1.jpg)
The Internet of Things or IoT technology is booming nowadays. Almost all makers are getting interested towards this field of endless possibilities. The Arduino and the ESP8266 are strong bases of this awesome technology. But, what will happen if we merge an Arduino with an ESP8266EX under the same package? Well, the answer is “Radino WiFi”.
The In-Circuit Radino WiFi combines an ATmega32U4 with the popular ESP8266EX WiFi SoC to the small
Radino package. The ATmega32U4 MCU is also used in Arduino Micro. In Radino, the MCU is preprogrammed with Arduino bootloader. Hence, you can use Arduino IDE for uploading codes to this Arduino-compatible device. In-Circuit stated on their website:
It′s part of the radino-series, which provides full Arduino-compatible wireless communication devices in a small form factor, all pins are compatible with each other.
Features:
- Arduino-compatible
- Fully integrated WiFi Chip ESP8266EX by Espressif
- 802.11 b/g/n protocol
- Wi-Fi Direct (P2P), soft-AP
- Integrated TCP/IP protocol stack
- Integrated TR switch, balun, LNA, power amplifier and matching network
- +19.5dBm output power in 802.11b mode
- ESP8266 Power down leakage current is < 10uA
- Wakes up and transmits packets in < 2ms
- ESP8266 Standby power consumption is < 1.0mW
- 15 GPIOS (7 PWM, 5 Analog IN)
- I²C, SPI, UART
- USB (HID Keyboard & Mouse, virtual UART)
- High-Performance, Low-Power Microcontroller ATmega32U4
Technical Details:
Radino WiFi consists of two chips. An ATMega32U4 and an ESP8266EX. The ATmega32U4 is used as I/O machine for the ESP8266EX. It performs all the required tasks to control I/Os. In the other hand, ESP8266EX is the main WiFi chip and all WiFi services run only on the ESP.
The Radino comes preprogrammed with an ESP based web server. The default settings are given below:
- Access point: RADINO-WIFI
- Password: 12345678
- TCP/UDP service for UART-Bridge/WiFi
- Default IP: 192.168.2.1
The user can change these default settings anytime.
Download the Radino library for Arduino IDE 1.6 from here. Add this library to Arduino IDE and select Radino board from board manager.
This video explains how to use this amazing module.
Radino Pinout:
![Radino WiFi Module Pinout Diagram](https://www.electronics-lab.com/wp-content/uploads/2017/01/radino_Pinout_allgemein-1024x736.jpg)
Radino has 15 GPIO pins. Among them, 5 pins can handle PWM signal and 5 pins can take analog signal as input. Radino is powered by a 3.6V power source. Exceeding that value will damage the device.
Important Links:
- Wiki for Radino WiFi – Here you will get detailed information about this module and its libraries.
- Datasheet of Radino WiFi – Read the datasheet for an in-depth knowledge of this module.
- Arduino Library for Radino – Download required libraries for Arduino IDE.
- Radino WiFi Software – To get started, visit this page. Lots of documentations are given there.
Another video on this topic:
You can purchase Radino WiFi from shop.in-circuit.de. It costs only 19.90€.
