Radxa ZERO 3E SBC is Now Availabe for $15.99
In a previous post, we discussed the Radxa Zero 3W & 3E, both powered by the Rockchip RK3566 and designed to mimic the form factor of the Raspberry Pi Zero 2W and Orange Pi Zero 2W. At that time, Radxa had not disclosed its pricing. However, they have recently announced that these models will be available exclusively at the Arace Tech online store with competitive pricing.
The SBC is powered by an RK3566-based SBC which is a quad-core 64-bit Cortex-A55 CPU (up to 1.8GHz) with an ARM Mali G52 2EE GPU. They support OpenGL ES versions up to 3.2, Vulkan 1.1, and OpenCL 2.0, enhancing their graphical processing capabilities.
The SBC is versatile and can be configured with 1,2,4 and 8GB LPDDR4 RAM options. It also has a Micro SD slot along with multiple connectivity options including Gigabit Ethernet with PoE (extra HAT required), USB-C OTG, USB 3.0, and Micro HDMI (1080P@60fps). Additionally, it features a 40-pin header for extensive interfacing (UARTs, SPI, I2C, etc.), and dual power inputs (5V DC, 3.3V).
Radxa ZERO 3E SBC Specifications
  • SoC: Rockchip RK3566
  • CPU: Quad-core Arm Cortex-A55 (ARMv8) 64-bit @ 1.6GHz
  • GPU: Arm Mali-G52-2EE, supporting OpenGL ES 1.1/2.0/3.0/3.1/3.2, Vulkan 1.1, and OpenCL 2.0
  • RAM: Options for 1GB, 2GB, 4GB, or 8GB LPDDR4
  • Storage: Micro SD card slot
  • Ethernet: Gigabit Ethernet port with PoE support (additional PoE HAT required)
  • USB: USB 2.0 Type C OTG and USB 3.0 Type C Host
  • Display: Micro HDMI port supporting 1080P@60fps
  • Camera Interface: MIPI CSI camera port
  • GPIO: 40-pin header supporting various interfaces including:
    • Up to 5 UARTs
    • 1 SPI bus
    • Up to 2 I2C buses
    • 1 PCM/I2S
    • Up to 6 PWMs
    • Up to 28 GPIOs
  • Power: 2 x 5V DC inputs, 2 x 3.3V power pins
  • Operating Conditions: Optimal between 0°C to 50°C; throttles at 80°C to prevent overheating
  • Cooling: External cooling (heat sinks, fans) is recommended for continuous high-performance operation
  • Certifications: CE, FCC
  • Dimensions: 72 mm x 30 mm
Radxa indicates that the ZERO 3E will be compatible with operating systems like Debian, Ubuntu, and Android, catering to various uses. Last time when we wrote about this there was no documentation available but this time around the company has provided us with reliable documentation, you can check that out on the company docs page.
The Radxa Zero 3E comes in three variants: 1GB RAM for $15.99, 2GB RAM for $20.99, and 4GB RAM for $30.99, available only at the Arace Tech online store.
About Debashis Das
view all posts by das
