![Real Time Clock and Temperature Monitor using DS3231 Module Real Time Clock and Temperature Monitor using DS3231 Module](https://www.electronics-lab.com/wp-content/uploads/2017/10/ds3231-image.jpg)
The DS3231 is a very low power RTC chip, it has the ability to keep time with incredible accuracy such that even after power has been disconnected from your product, it can run for years on a connected coin cell battery. This module has the ability to communicate via I2C or SPI but for this tutorial we will be using the I2C mode for communications between our arduino and the DS3231. The module also comes with a quite accurate temperature sensor which we will be using to get temperature readings. The collected temperature and clock data is then displayed on the 16×2 LCD via the Arduino.
Real Time Clock and Temperature Monitor using DS3231 Module – [Link]
Login
