![Renesas Electronics FS1015 Air Velocity Sensor Module Renesas Electronics FS1015 Air Velocity Sensor Module](https://www.electronics-lab.com/wp-content/uploads/2021/10/199413099.png)
Mouser Electronics is now stocking the FS1015 and FS3000 airflow sensor modules Renesas Electronics. The vertical-mount FS1015 and the surface-mount FS3000 provide precision airflow monitoring for detecting system failures, measuring air handling, controlling fan speed, and more in HVAC systems, analytic gas-monitoring systems, data centers, and air quality systems.
The FS1015 and FS3000 sensors, now shipping from Mouser, use a series of MEMS thermocouples to provide high-sensitivity air monitoring. Both sensors measure direct local air at up to 15 meters per second, allowing system control to adjust quickly, providing closed-loop control while achieving maximum efficiency and cost savings. The solid thermal isolation of the MEMS sensing element combined with a silicon-carbide film offers excellent abrasive wear resistance and long-term reliability.
The FS1015 comes in a 28.2 mm × 14.2 mm × 7.3 mm package with leads for vertical mounting and screw-secured side tabs. The FS3000 module is available in an 8.0 mm × 9.1 mm × 4.4 mm surface-mount package ideal for low-profile applications.
- Airflow: 0m/sec to 7m/sec, 0m/sec to 15m/sec
- MEMS Thermopile sensing
- Silicon-carbide coating over MEMS flow sensor
- 5V supply voltage
- Digital and analog output
- Fast response time
- Vertical-mount module
- 28.2mm x 14.2mm x 7.3mm
more information: https://www.renesas.com/jp/ja/products/sensor-products/flow-sensors/fs1012-gas-or-liquid-flow-sensor-module
