![Replacement LED driver for AN6877 Replacement LED driver for AN6877](https://www.electronics-lab.com/wp-content/uploads/2015/12/aflevelmeter.png)
Dilshan Jayakody has designed a board to replace AN6877 base LED drivers using discreet transistors. He writes:
AN6877 is linear AF level meter IC produced by Panasonic and it is commonly found on many audio equipment. This chip is no longer manufactured by Panasonic and finding replacement chip for AN6877 is also quiet difficult.
The circuit described in this article is design to replace AN6877 base LED drivers and it is based on commonly available components. This replacement LED driver is design using 10, MMBT3904/2N3904 transistors and it can easily modify to get necessary number of outputs.
Replacement LED driver for AN6877 – [Link]
Login
