Rikomagic RKM MK42: Compact Mini PC for Retail Kiosks and Digital Signage
1.073
Rikomagic, a Chinese manufacturer specializing in digital signage solutions, has introduced the RKM MK42 Mini PC, designed for business-focused applications such as digital signage, retail kiosks, and IoT gateways. This compact device is powered by the 12th Gen Intel Processor N100 from the Alder Lake-N family, featuring 4 cores, 4 threads, a base frequency of 0.8GHz, a maximum turbo frequency of 3.4GHz, and integrated Intel UHD Graphics with 24 execution units (up to 750 MHz).
The RKM MK42 is equipped with 12GB of RAM and a 512GB SSD, and supports Windows 11 as its operating system. Connectivity options include dual Gigabit Ethernet ports, Wi-Fi 6, Bluetooth 5.2, and five USB ports. The Mini PC supports dual 4K@60Hz displays via one HDMI port and one DP++ port, and it includes a 3.5mm audio jack for additional flexibility. BIOS features such as Wake-On-LAN (WOL) and Auto Power On enhance its utility for business environments.
Previously, we covered several Mini PCs powered by the Intel N100 processor, including the MINIX Z100-AERO, MeLE PCG02 Pro, MINIX NEO Z100-0dB, Topton M4, MS-1P17 Ultra Slim, and others. Feel free to explore these products if you are interested.
Rikomagic RKM MK42 Mini PC Specifications:
  • SoC: Intel 12th Gen Processor Alder Lake-N100 (6M Smart Cache, up to 3.40 GHz)
  • GPU: Intel UHD Graphics (24 EUs, up to 750 MHz)
  • System Memory: 12GB RAM
  • Storage: 512GB SSD
  • Video Output
    • 1x HDMI 2.0 port (4K display @ 60 Hz)
    • 1x DP++ 1.4 port (4K display @ 60 Hz)
  • Audio Output
    • 3.5mm audio jack
    • Digital audio output via HDMI and DisplayPort++
  • Networking
    • 2x 1Gbps Ethernet RJ45 ports
    • Wi-Fi 6 (802.11a/b/g/n/ax)
    • Bluetooth 5.2
  • USB
    • 4x USB 3.2 ports
    • 1x USB Type-C port
  • Misc
    • 1x Power button
    • cooling fan
    • Wake-On-LAN (WOL)
  • Power supply: 12V DC-in via DC power jack
  • Dimensions: 131 x 131 x 43 mm
  • Weight: 361 gm
The RKM MK42 features a compact and lightweight design, measuring 131 x 131 x 43 mm and weighing approximately 361 grams. It is packaged with a 12V/2A power adapter and an HDMI cable. While details about its cooling system are not specified, the device is likely equipped with active cooling.
Currently, the Rikomagic RKM MK42 Mini PC is not listed on AliExpress or other online retailers. Distributors interested in pricing and detailed specifications can contact Rikomagic directly through their website.
About Sayantan Nandy
view all posts by sayantan
