![Rohde & Schwarz HMC8012 Digital Multimeter with 5-3/4 Digit Display (480,000 Counts) Rohde & Schwarz HMC8012 Digital Multimeter with 5-3/4 Digit Display (480,000 Counts)](https://www.electronics-lab.com/wp-content/uploads/2019/01/HMC8012_front-1024x546.jpg)
The HMC8012 provides a diverse choice of easily accessible measurement and mathematical functions. Multimeter is able to simultaneously display up to three measurements that are now even easier to read from a crisp color TFT display. Considering the compact size of HMC8012, it will fit perfectly both on a bench and on a shelf. Other specifications: Measurement range: DC to 100 kHz. Resolution: 1 μV, 100 nA, 1 mΩ, 1 pF, 1 Hz, 0.1 °C/F. Measurement rate: up to 200 values/s. Measurement functions: V (DC), I (DC), V (AC), I (AC), frequency, DC power, resistance (two and four-wire), temperature (PT100/PT500/PT1000), capacitance, diode and continuity test.
Key Facts
- Measurement range: DC to 100 kHz
- Resolution: 1 μV, 100 nA, 1 mΩ, 1 pF, 1 Hz, 0.1 °C/F
- Basic accuracy: 0.015 % (DC)
- 5¾-digit display (480 000 counts)
- Simultaneous display of three measurement functions, e.g. DC + AC + statistics
- Measurement rate: up to 200 values/s
- Measurement functions: V (DC), I (DC), V (AC), I (AC), frequency, DC power, resistance (two and fourwire), temperature (PT100/PT500/PT1000), capacitance, diode and continuity test
- Mathematic functions: limit testing, min./max., average, offset, DC power, dB, dBm
- Data logging to internal memory or USB flash drive in CSV format
- Interfaces: USB-TMC/-VCP, Ethernet, LXI, IEEE-488 (GPIB)
- SCPI commands largely compatible with Agilent 34410A (HMC8012-G)
- HMC8012-G: HMC8012 incl. IEEE-488 (GPIB) interface
Review Video
Rohde & Schwarz HMC8012 Digital Multimeter costs ~£650.00 from various distributors online.
Login
