TME’s offer features miniature modules for monitoring environmental conditions from R&D SOFTWARE SOLUTIONS. The manufacturer offers the modules in several different variants differing in terms of the number and type of embedded sensors.
You can select from pressure sensors, temperature sensors, humidity sensors, CO2 sensors and VOC (Volatile Organic Compounds) sensors. The systems are powered within the range of 3.3V DC to 5V DC, which means they can be used with the most common platforms, such as Arduino, Banana Pi, Raspberry Pi, Beagle Bone, or Teensy.
The I2C communication requires the use of two microcontroller lines, regardless of the number of connected modules. This makes R&D SOFTWARE SOLUTIONS products useful even in basic systems with a limited number of pins.
Specifications
- Communication standard: I2C
- Available sensors, CCS811 , HDC2010 , BME280, BME680, BMP280
- Supply voltage: 3.3/5V DC
- Operating temperature: -40⁰C to +80⁰C
- Dimensions: 13x27mm
- Weight: (without wires) 2g
more information: s-Sense modules »
